Smart phone hardware hack
My Samsung Vibrant (SHG-T959) recently experience a screen failure. No idea how, it was not dropped, gotten wet, etc. Just in my pocket around the house and when I pulled it out, no screen. The capacitive touch still works but I cannot see anything. I still have a lot of photos and contacts on the internal sd and if I could figure out the CyanogenMod layout for connecting to USB i think I could get it. I tried guessing where the buttons were for a long time now and I cannot get it. I needed a new phone so it no longer has a sim and I now have I micro sim so IDK what other menus might be up. What I would really like to know is how I could rip into the phone from the computer end because the memory is attached to the phone. Once I have some stuff off I have no problem taking a soldering iron to it and trying to fix it but at this point there are some things I would really lke off of it. I tried a couple differnt things online but I remember that this version / install does not auto connect to USB and you have to press a button and without that they all fail because the phone isn't communicating at all with the computer.
Thanks
What version of CM are you running?  If it's CM 9+ when you plug it in a screen like this should show up:
(only in whatever language you run)  You need to press that button to change to storage mode and get access to the file system.
Cm 10. I can't see the image attached to your post. Could just be my tablet. If you could message that to me that would be great.
