Smallest case possible for my parts
I bought a Zalman z11 plus but it's kind of big and I was wondering what case would be the smallest one I could put my pc parts in.
My parts:
Intel Core i5-4670K - 3.4GHz - Socket 1150
ASUS GeForce GTX760-DC2OC-2GD5 - 2GB - PCI-E
ASUS Z87-K - Socket 1150 - ATX
Cooler Master Hyper 212 EVO - 120 mm
Seasonic M12II-620 Bronze - 620 Watt
Crucial RAM, two 3,5"HDD and one 2,5"SSD
Would have though a small LIAN LI case, like the PC-A05FNB
Apevia X- master black HTPC
Aerocool DS-cube
nMEDIA 8000
I myself would recommend this http://www.newegg.com/Product/Product.aspx?Item=N82E16811281007 over the LIAN LI. The Nanoxia sacrifices a few pci slots to have the power supply in the back, this way the op has direct access to the rocker switch in case something happens. Plus it has modular drive bays that remove from the side, so the op can remove what he doesnt use and better his airflow.
Op has a fully modular psu, so that helps alot. The only problem I can see going with smaller cases besides reduced airflow, is the cases can get a bit narrow for the Hyper 212. Ive seen this with the Tempest/Source 210 first hand. You might be able to file down the ends of the copper pipes just a little to make it fit if you have clearence issues, however Ive never tried it so Im not sure if this would affect cooling so dont take my word for it.
He wants to keep all his parts he listed up above. None of those would work with his setup even though the cube and the nMedia look cool.
nMEDIA 6000B would be fine
Or Fractal Designs Define R4
It only supports Micro-ATX / Mini-ITX :/
It's only 3,4cm smaller in height than the one I have now
I can't find where to buy it in Belgium and on Ebay it costs 70,00 € for transport alone :/
Looks nice, I might go for that one
Cooler master haf xb EVO is my recommendation.
Which case? All the cases I suggested support atx. Nanoxia NXDS4W, and Fractal Design Define R4
http://www.newegg.com/Product/Product.aspx?Item=11-352-020
You arent going to get much smaller without sacrificing parts like your drives or cpu cooler unless you trade out your motherboard for a smaller form factor. But I assume you already have windows installed, right?
Keep in mind airflow as well. You arent going to cram $800 worth of parts into anything like a htcp case like some people are suggesting. If you are really cramped on space, you could do a decorative piece on a wall to mount your parts to.
