Anyone have any suggestions for a sleek and quiet case that can fit at least two 240 radiators without being "massive"? I was considering the Corsair Carbide Series Air 540. The price isn't terrible and the design fits my workspace much better.
I hate the side panels and the window though. I'll probably be loading it up with Noctuas so I'm not keen on seeing inside. The price isn't bad but I can't help feeling there is probably something better out there. Any suggestions?
How thick are the rads, and what is the max budget? I assume you're running an ATX motherboard?
Define r4 or Arc Midi r2. They're both cheap, well built, small, and support two 240mm rads of any thickness. Although, an 80mm thick rad up top is a squeeze.
Pretty sure it'll be ATX but I'm not sure about the rads. This will be my first liquid cooling venture. I won't be building it for a few months at least but I was gunna start with a 240 or 280 at the top for just the CPU. When ready I want to add a second GPU with another rad in the front thats maybe a 320? Regardless, I doubt I'll be doing push/pull for the CPU rad.
The spot I have for the desk is really small, in fact this barely would fit in it. I mainly just want plenty of room for expansion in the future. I think this design really works as it's the right length without being excessively tall as well, as it sits on the side of the desk.
