I'm building a small PC for a friend and i wanted some opinion on my parts list.
http://pcpartpicker.com/p/yQYRRB
any reason for going with an i3? I would at least go for low end i5 and maybe not use an open cooler GPU in such a small case
If you've already thought of this then go for it
I went with an i3 just to save money. Do you think it will bottleneck the gpu?
yes it will definatly bottle neck a 980.
thats a dual core cpu, an i5 will only be another $70
Go with a i5 + 970.
ok thanks
updated build
http://pcpartpicker.com/user/slayer3726/saved/Qnq7YJ
