Small Gaming Build 2014
This will be my first build but I have been a long time PC gamer but I have been using a laptop. But now I'm Ready to use the big boys now. I am just wondering if this will all fit in the case and will start up. I am also looking to see if there is anything I should change. Mostly this will be used for moderate gaming such as minecraft and a few small indie games, but I would also want to play some major games on low in the future. I have an OS so no need to worry about that. I hope this lasts a while so I don't know if there is anything I can do to future proof it more. Thanks
CPU: Intel Core i5-3350P 3.1GHz Quad-Core Processor
Motherboard: ASRock B75M R2.0 Micro ATX LGA1155 Motherboard
Memory: Crucial Ballistix Sport 4GB (1 x 4GB) DDR3-1600 Memory
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce GTX 660 2GB Video Card
Case: NZXT Source 210 Elite (White) ATX Mid Tower Case
Case Fans: 2x NZXT Air Flow Series 59.1 CFM 120mm Fan
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply
Optical Drive: LG GH24NSB0 DVD/CD Writer
Swapping to an AMD 6300 and an equivalent motherboard would drop the price $40 in that area, and allow you to grab a better graphics card or dual channel RAM, but would bring your minimum PSU rating to 500/550w if getting a new GPU. a 430w psu limits expandability since you cannot use anything much better than your 660.
The i5 is the main thing i would ditch, at this price point it doesn't make sense. It also uses an outdated socket, although the life of AM3+ is questionable at the moment.
Get an 1100t. Get a CrossHair IV Extreme. Don't get an Optical Disk Drive. Use a cardboard box as a case. Get 2x8GB of Double Data Rate III SDRAM. Don't do case fans. Get a GTX 770. Get a better PSU. What monitor do you currently have? A 770 is enough for 1920x1200 60Hz, but not 144Hz or 2560x1600. My R9 290 barely pushes 2880x1800.
^For future reference, never listen to anything this guy posts here.
Shiggles has lost if from sniffing gasoline too much. Don't listen to the crazy guy. I'm the forum ruler.
What's your budget? And what is your monitor's resolution?
We measure distance with this man ^ .
I actually like rabidz lol.
Looking at the parts you picked, it appears your budget isn't the greatest.  An AMD build here would be more optimal.
Around $650(not very much) and 1600x900
How is this?
PCPartPicker part list: http://pcpartpicker.com/p/2SfGL
CPU: AMD FX-6300 3.5GHz 6-Core Processor
Motherboard: Asus M5A78L-M/USB3 Micro ATX AM3+ Motherboard
Memory: 2x Crucial Ballistix Sport 4GB (1 x 4GB) DDR3-1600 Memory
Case Fan: 2x NZXT Air Flow Series 59.1 CFM 120mm  Fan
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply
For the kind of gaming you want to do and the budget you have, would an APU be a better way to go?
The one and only who does lolololo but seriously
AMD Matx Motherboards are horrible. They're not any that I can recommend. Intel is the smart choice for lots of power in a small form factor. The motherboard you choice is really no offense, a horrible board.
This is tiny form factor 2014 http://pcpartpicker.com/p/2SgRv
That is indeed not a bad build.
Im really glad that i do reserch and ask for feedback. If i wouldent have been hear i might have just gotten it. Would there be any mobo for under 65-70 for an i5?
With how high the memory prices have been maybe a dedicated gpu would be better.I may also play some more graphics intence gams that rely on a good gpu.
