Small delema
I have a gigabyte mc62 g40 mobo
the issue is one of the mini sas connectors is giving communication issues in my unraid server ( 12 hotswap bays)
now Im able to get all 12 hard drives connected via the other 2 mini sas and sata ports or an hba
should I rma the board or just continue on without the 3rd mini sas connector
the reason Im debating is because it will take a month plus that the server in my homelab will be down ( its my plex server)
kinda on the fence and just looking for some opinions on what route i should go down …
Welcome, have you tried anything to fix it or just debating between the both options right now?
how would i go about fixing it?
i switched cables to a known good one got the crc error on the same drive … switched around the 4 sata plugs that came off the mini sas cable and the crc error followed the sata plug to a new drive …
currently I have 11 of the drives connected via the mini sas to sata and the 12th drive connected via a sata port on the motherboard and everything is working fine …
So with that said unless i need more than the 12 drives which the chassis dosent really support all is fine … thats why im not sure if its worth the shipping and down time to worry about it …
I dont think ill max out my available data bandwith as really its just a plex/ nas and im not editing off it or doing anything really data heavy and its on a 10 g network
Believe it or not it’s probably not the board just the variability of all the components plus cables. It’s likely trying a shorter cable for the problem connector will resolve it.
Hba is also fine.
Fundamentally the onboard connectors are sata not sas which have a lower snr ratio. Hbas are true sas which is higher snr typically. And works best over longer distances and via backplane.
so in the situation how would I figure that out or solve it if its not a RMA need?
it would be nice to keep the nice small mini sas to sata cables and thier routing as tthose ports are in a more optinal position for my setup … or am i just kinda relegated to running some of the drives on sata ports off the board?
my cables im using are only 18 inch and i have not been able to find any shorter and im not sure shorter would even reach so am i best to just abandon trying to use all 3 mini sas ports on the MB?
Yep. And that’s not a typical. If youve ever watched my mobo reviews I hate on the slimsas stuff pretty universally because real world it’s a pita
If you go into an icy dock or backplane with redrivers it can be fine. It can be fine with cables l. Sometimes it’s not tho
I do watch just never really clued into the hate LOL
yeah its just in a reosewill 4u with the 12 hotswap bays and each drive has its on connector so Im guessing its just a passtrough type situation … like I said not the end of the world as I do have ways around the issue and they seem to be working fine. Just didnt want to shut down a server for month or more unless it was something I really should do .
And all honesty I didnt actually expect you yourself to reply … Kinda cool actually that I got answered by Wendell with my first time on the forum … It really does show something about you. And I admire that mentality.
Thank you
because I was always curious to see the eye diagrams of the two protocols compared:
SATA 6Gbps running through 32" of cable before and after redriver
SAS 6Gbps running through 32" of cable before and after redriver
notice the ~470mV eye height for SATA versus the ~710mV eye height for SAS. SAS also has better jitter.
for those wanting to dive deeper into SAS/SATA redrivers:
