Anyone know of any small ATX computer cases. I've been a HAF Full Tower user since the series came out and boy am I tired of carrying that big son of a bitch around.
Any links?
I was checking that one out. Solid case.
Honestly, almost anything is smaller than the old HAF full towers... I mean Jesus Christ, if i put one of them on the ground it comes as high as a standard table...
Anyways... Not the smallest, but those are three best ATX cases imho...
NZXT H440
Phanteks Enthoo Pro M
Fractal Design Arc Midi R2
I asked this same question a little while ago. Here's the thread: https://forum.level1techs.com/t/what-is-the-smallest-atx-pc-case-that-you-know-of/107215
Sweet thanks! I'll check it out!
Thats awesome. I love that case.
There is this that wendell did a build in a while ago:
http://www.lian-li.com/en/dt_portfolio/pc-a51/
Cant find a place to buy it though
Actually I am looking for a similar case, but preferably this form factor:
http://www.lian-li.com/en/dt_portfolio/pc-o7sw/
Is there a cheaper one?
Fractal Design Node 605
Unless you want all of your components to be burning hot at all times, no.
Well there is always Silverstone gd09b
https://www.amazon.com/gp/aw/d/B00KHO0MRK/ref=mp_s_a_1_2?ie=UTF8&qid=1478800238&sr=8-2&pi=SX200_QL40&keywords=fractal+node+605&dpPl=1&dpID=31GmL-GVmOL&ref=plSrch
PS: honestly I haven't used any of those... They just fit the criteria somehow...
Hmm. I like that one. I think Ill order it and try it out, then Ill report back.
Hopefully it isnt too tall.
