Ok, I have a FiiO E18 (Kunlun), which is a portable headphone amp/dac for phones but I don’t want to use my daily driver with it. I want a small and cheap device that I can just glue onto that sucker and effectively make it one unit. So, best case scenario would be a device like …
cheap (100,- Euro or so)
4" screen or less up to 5" screen depending on bezels
USB on the bottom
microSD slot
flat back
android with google services
the less bloat the better
Use case: I wanna play shit from it. Like music and podcasts … and maybe youtube videos. Basically iPod use with sound going out over USB to the DAC/AMP.
Suggestions?
[EDIT] Found a photo of the FiiO’s backside, so that would be the area for the phone.
Do you know what the drawbacks of android go are? I mean, does that still have all USB functionality to connect to DACs for example? And what about apps?
EDIT - It seems like OTG does not work with that device. Haven’t found information if that is a hardware or software limitation. If it’s the latter, Android GO is out.
Just comes with some google apps that are meant for lightweight devices, you can still install regular apps.
Doesn’t have any limitations to my knowledge.
I don’t know about Germany, but my carrier is selling Samsung A10 (A105F) for 100euros flat.
There is also Nokia 3.2 that I hate to recommend, but it fits everything you ask for - no bloatware, all Google stuff, Memory card slot etc etc. Just don’t use it to listen to music on it.
The reason I asked was that maybe a phone is not the optimal piece of electronics. Have you had a look at a Sony A55 Walkman? I think it will do everything you want, and be smaller, lighter and run for longer than a phone.
Doesn’t run android, won’t play youtube or podcasts or google music…
Not to mention it’s way more money than a cheap phone and probably won’t USB OTG to the amp I already have.
Please don’t comment with random stuff.
If you want to help, please actually read what I write.
Thanks.
LG G6 might be a good option, plus it has a great Quad DAC headphone jack, might be useful? I still see them coming up as new items for a pittence on Fleabay.
