I have an old thin client, a wyse Cx0.
1ghz 32 bit cpu
2gb ram
32gb flash
I want to make it into at the very least a print server, likely using cups, and if it is powerful enough maybe service like pihole and homer, both low usage.
I have mostly used distro’s in the red hat style and would pref to stick more with what I know, but have had very limited linux use in the last few years (I do run an alma vm with docker on it but have not done much with it).
I would also like it to be fairly cut down as other than these functions it does not need to do anything.
And obviously needs to be a distro that has a 32bit version easily available.
Debian… Nowadays, most distributions are heavy, or to be more precise, software is hell heavy.
I used to install debian on P4 for fun and 512MB RAM with xfce, it worked, but apart from operating in the menu it was a waste of time, firefox was a killer.
In contrast, I currently have a Cortex-A7 with 512MB with Debian 11 + pihole and it’s doing great.
You have 2GB of ram … so there is no tragedy, but the cpu is a snail, it will work especially without the gui, with the gui it will probably be less pleasant. But as a print server or something small it should manage to some extent.
I would start by testing Debian 11 and see how it works. Other more dedicated small distros will still have a similar cpu load as debian, the main difference will be only in the amount of ram required, while you don’t need a distro that for example runs on 128MB…
CentOS-7 has an i386 release you can use. Supported for about another year. I’ve got it on an old netbook, it installed and worked on 1GB or RAM. Works fine, but definitely holes in the 32-bit software selection… I had to do a lot of compiling from source RPMs to fill-in missing dependencies. And once you’ve gone that route, how do you know when updates are available??? It works alright, but not ideal. And it’s the end-of-the-line… I don’t expect any such options will be forthcoming for any newer RHEL releases.
I don’t believe you’ll find any other RedHat-like options, so you’ll need to give-up on that point.
Even $30 thin clients are mostly 64-bit these days (10years old but usually 64bit) and so are various small arm boxes and boards, it’s getting tough.
OpenWRT … super tiny
Alpine … a bit more comfortable with hardware, lot saner package build flags for something as large as your thin client
Debian … yeah 2GB ram will fit kernel and filesystems and a couple of systemd managed daemons.
I haven’t really used Alpine out of containers and VMs, but it sounds like the right mix for what you have, OpenWRT packages and kernel are very stripped down, e.g. great if you have 64MB of ram, with 2GB you can live a little and get big SSL and Unicode libraries and maybe even some Go software like Caddy or other stuff to serve http and manage your SSL cert rotation.
IMO ram is the limiting factor in this case, not the “bitness” per se.
Alpine Linux is really your best bet if you want the smallest footprint distro possible, but it comes with some downsides, such as using rc init system and busybox instead of systemd and gnu tools
Thanks for all the replies and help, a few distro’s to look at.
And forgot to say I would not be using a gui so that isn’t needed.
I have used Tiny Core before but for some reason I had thought it had been abandoned, I was incorrect so I will try that first.
32bit is the major issue and I probably should just buy a cheap 64bit thin client off ebay but I have this one and it is only 7 watt power draw at idle which is not bad.
i concur debian is probably the best option.
x11 is absolutely usable.
but if you really must, most distros will have archives you can raid and find what you need.
its just a case of googling distro name + “32bit version” will in most cases get you there.
when you apply quotes to a google search your telling google that the search must include.
I use bunsen linux, which itself sits on top of debian on an early atom palmtop and in a vm or two I like to keep lightweight but graphical. Pretty happy with this, but expect a post-install text adventure.
