I have a 1TB SX8200 Pro. These are the speeds I am getting:
They’re not terrible but definitely not the full speeds or what I am seeing in benchmarks.
I use a Dell XPS running Windows 10, with SATA mode in BIOS set to ‘RAID’, and with the latest Intel RST drivers (16.8.3.1003) installed.
Has anyone seem the same with the SX8200 Pro?
ADATA doesn’t provide their own firmware/drivers and advises the use of standard Microsoft/Intel ones. I have seen some alternative drivers available for download at win-raid but I haven’t given them a try yet.
It’s definitely a PCIe 3.0 4x lane. It’s on a Dell XPS 9550.
I have near 500GB of data and thought cloning would be the faultless way… I will attempt a clean install next week, just ordered a NVMe to USB enclosure so I can backup data to my old NVMe drive before I reinstall Windows on the SX8200 Pro.
2 options that you can try, SSD optimization, if it doesn’t help defragmenting, defrag isn’t a thing you normally do to a SSD, but it does help doing it in some cases and although it will burn some writes it can be well worth doing it.
Please note, don’t defrag them weekly, or something stupid like that, defrag for a SSD is 1-2 times in lifespan option.
Yeah they did switch, but to explain the changes
1)controller switch has been pushed by SMI every time SMI decides they don’t want to produce the old controllers and well the changes made are pretty small and SMI usually understands better what needs to be done than reviewers and end-users
2) there has been side-grading for NAND due to supply limits and from what I can tell all companies that aren’t directly under one of the NAND manufacturers are rotating and bidding on what they can get, ADATA has been avoiding to use Toshiba/SanDisk NAND on the models that haven’t come with it in the original specification, which IMHO has been a good thing as the rest of the NAND doesn’t really have such reliability issues
