Slow wifi speeds w/ Intel AX201 & PopOS
I recently converted my laptop (Asus ROG Zephyrus M15 GU502LW 2020) from dual boot (Windows 10 + Fedora 35.) Fedora had presented a lot of problems handling Optimus, so I decided to move to PopOS’s Nvidia release. And indeed it does seem to handle gaming with Optimus better, not needing any special env variables to run on the Nvidia GPU. I was also able to run Cyberpunk 2077 with RTX and DLSS and enabled…very nice indeed.
But the rub comes when trying to use WiFi. The laptop is equipped with an Intel Wifi 6 MiMo 2x2 AX201 chip. For some reason Steam downloads are unreasonably slow, usually between 4 MB/s and 8MB/s. For comparison, my MacBook Air (w WiFi 5) in exactly the same location gets 25 - 30 MB/s. I believe Fedora was usually getting about 15 - 20 MB/s, but since I wasn’t anticipating a problem I didn’t benchmark it.
Is there anything I can do to improve this? Any recommended troubleshooting procedures?
What AP/Router are you using, is this same room as access point?
Driver(kernel module)+firmware being loaded on startup are what control power and picks MCS and handles CSMA/CA and aggregation. wpa_supplicant can interact with it to change things somewhat, but assuming you’re just connecting at a typical 80MHz channel width 2x2 with AP on the same room there’s only so much you can do from user space.
Have you compared dmesg between fedora and pop, have you tried different kernels?
Definitely not the AX201 IMO, used the AX201 with PopOS a few months ago, didn’t face any issues.
Netgear AC1450 with DD-WRT (updated about 2 months ago). The router is about 25’ away in another room, with an additional hall in between. Fedora was completely wiped, so I don’t have any logs to compare to.
I have not tried any other kernel than the one that ships with PopOS.
It is possible that something else on the network was hogging bandwidth, but it would have been a Windows or other software update that lasted multiple hours. There was a washing machine running about 30’ away at the other end of the house, but I don’t think that would create anywhere near the same interference as a microwave.
@AviatorMaverick Thanks for the data point. Do you happen to remember which PopOS release you were using?
I’m using an AX201 on my laptop and was using 20.04 and 22.04 of Pop_OS! until recently. I got up to 90 MiB/s in close proximity to my Unify U6 lite.
I don’t think the AX201 or PoP is the problem here. For me it was just plug&play and I never had to tweak anything
20.10 (with NVidia drivers)
Even though many distros have ironed out Wifi 6 support, I have my doubts about it being driver/AX201 related.
I’d suggest running a few speed tests between devices, if that Netgear model has a similar antenna as my parents former R6250 it could be the 5G wireless part of the router isn’t working properly. From personal experience of my parents wifi networking hell, the low-profile antenna instead of external antennas tends to skew the range and as the router 2.4/5G amplifier degrades from age you’ll experience random bursts of speed/drops of speed.
Thanks for helping me get a clue. Found this in dmesg:
iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-69.ucode failed with error -2
…which led me to this bug report:
Even though the bug was dismissed by the maintainers, the reporter left a clue:
cp iwlwifi-QuZ-a0-hr-b0-68.ucode iwlwifi-QuZ-a0-hr-b0-69.ucode
Indeed copying that file to the new name (there was no pre-existing file to be copied over) partially fixed the problem. Now I’m seeing download speeds of around 10 - 12 MB/s. That approximately doubled my speed, but it’s still not where it should be. Any idea why PopOS would be missing this firmware file?
Well that’s looking better…
I logged into my router and tried changing all sorts of settings. Locking the 5GHz band to 802.11ac, changing the bandwidth from 20Mhz to 80Mhz, enabling beamforming, none of it seemed to matter. What finally worked was locking the 5GHz transmitter to channel 157 at 5.8xx GHz. :man_shrugging:
This page says:
Firmware
If not installed by your distribution already (check the packages) you can get the latest firmware from
linux-firmware.git.
… and it also explains what distributions are meant to do and where they’re supposed to be getting firmwares from.
My guess is fine folks at pop, maybe weren’t as diligent in ensuring linux-firmware package version matches the kernel iwlinfo driver version… could it be an nvidia driver causing them to mess with kernel versions in the first place? maybe.
So the git repo provided this firmware file:
iwlwifi-QuZ-a0-hr-b0-71.ucode
…with no sign of a -69 revision anywhere. With the *71.ucode file in /lib/firmware, the kernel completely ignores it and falls back to a really ancient version that I first ran into. If I manually rename the file from *71.ucode to *69.ucode, dmesg complains that it is two api versions ahead of my hardware, and then proceeds to load the *68.ucode firmware. This seems to work, though I suspect some features or performance are being left on the table.
Weird crap indeed.
