Hello all I am a new PC gamer and I am making my first PC build.
i am going to be using the i5 3570k and I have been looking at the Asus P8Z77-V LE but now I'm thinking maybe I should go with the LK so in the future I could SLI 760's granted I would probably need to go higher that my 600w PSU. Or is SLI not really worth it?
Not worth it because of hassles and the fact that not all games will benefit from it. In general I say save up and replace the existing card. It's really working best for those who have a reason to buy two high end cards at the same time.
i would personaly advice to pickup a better mobo anyway.
Msi Z77- GD65 Gaming for example this board is on a good price, supports sli and CF and its has some cool feutures. like killer nik lan chip .and it also looks awesome in my opinnion. it also is a much better board then the asus it has a better powerphase design. 12 powerphases,
But if you realy want a top notch board then i would recommend the Msi Z77 Mpower. this board has everything you want cf/sli support great overclocking feutures, also bluetooth and wifi onboard.
I'm a fan of SLi. My two GTX 660s will outpace a 780 on some benchmarks. Of course said person with a 780 would only have to add another 780 to blow me away.
I just don't know if I will use SLI so I don't know if it will be worth paying more for a SLI-able board. All I know for sure is I will want to be able to do a bit of over clocking a bit down the road.
from everyone else I have heard from asus is a way more reliable mobo brand than msi.
I've never benched bf3, and I play with vsync on. I've never seen less than 55fps and the vast majority of the time it's at 60fps.
I just ran Unigine a minute ago to answer this more satisfactorily to you, and I got a score of 1194. The last 780 bench article I saw had it 100-150 points less.
EDIT: I play BF3 with all settings on ultra @1920x1080. Unigine was run with DX11, Ultra Quality, Extreme Tessellation, x8 anti-aliasing and 1920x1080 resolution.
Its just a bit out of my price range, unless i can get a killer deal on it come black friday when im buying everything. I still haven't decided whether im going to SLI in the future or not.
