I have a question regarding my pc's hardware. I am currently running this setup:
Intel core i5 3570K @ 4.2 Ghz
Cooler master Hyper 212 CPU Cooler
MSI Z77A-G45
Seagate 500 gb hdd Sata 600
Crucial Ballistix 8Gb 1600 Mhz
Corsair cx Builder 600 watt psu
Toshiba 140 gb hdd sata 300
Evga GTX 650 Ti Boost 2gb
samsung optical drive
4 fans in total
So my Q is can I put another 650 ti boost in there? I know it will be a thight fit because of the psu. And my second Q is, when I do put another card in my system do I still need one of those SLI bridges?
Thanks in advance!
Greetings from the Netherlands
ps. Does the second need to be from the same brand?
Looking at your motherboard it should fit another graphics card just fine. I took the time to look at your motherboard's manual and it says SLI should go into PCI_E2 and PCI_E5 which are (From the top) the first and 2nd blue PCI-E slots. So You should have no problems fitting them.
You do need an SLI bridge which does not ship with the card itself :/ The brand doesn't matter
The GTX 650 ti boost is not a power hungry card. And neither are any of your other parts really. You have lots of room to work in even with the SLI setup.
