Gigabyte 560GTX OC (from start) 1Gb
MSi 560GTX NOT OC 1Gb
whats best if it even works. SLi them. or use the MSi card as PhysX
You will gain more from an SLI then a dedicated Phys X card
ok. i did read someware about it that my OC card will go down to the same as the other one but wasnt sure about it.
thx. play time tomorrow then :)
You would gain much more from SLI. Dedicated Phys X makes no sense with a 560. If you had a 460, or something lying around, and your main card was an AMD card, such as a 7950, then it would make more sense, but still, not very much.
