Hey everyone, my friend is doing a computer build and he is wondering what would be a good motherboard have to run two Geforce gtx 660's on for the future
He doesn't want to get anything higher than that at the moment due to money constraints and he is doing a AMD FX 8 core build.
I know most mobos support the pci slots at x8/x8, but I am mainly wondering if there are any that do x16/x8
I believe most of the 990FX boards will do two x16 lanes although I'm not sure on that. I know my Asus Sabertooth 990FX does dual x16 as does the M5A99FX Pro I had. Those are both excellent mobos though.
It doesn't really matter though it has been tested and running at x8 shouldn't hurt the performance.
Sli on AMD can only happen on a 990fx chipset motherboard. The asus 990fx pro, sabertooth and crosshair V formula are great asus boards. Note that the Asus 990x evo cannot support sli. Its a very recommended card and has the 990x chipset. 990x not 990fx and the fx is the required chipset for Sli. The AsRock 990fx killer and extreme9 are also great motherboards :)
- Asus crosshair V Formula Z
- Asus sabertooth 990FX R2.0
- Asrock 990FX Extreme 9
- Asrock 990FX Fatal1ty professional
- Asrock 990FX Fatal1ty Killer
- Asus M5A99FX Pro R2.0
Here is a list of decent motherboards that suppers an AMD 8 core cpu, and also dual sli at 16x.
Good luck choosing, if you have any questions about an particular board just ask.
Grtz Angel ☺
