SLI/Crossfire
Salutations Tek Syndicate,
   I have heard the terms SLI and Crossfire a bazillion times, and I have a rough understanding of it, but I am unsure as to how it helps besides giving extra places to plug monitors in(yeah I ended a sentence with a preposition, you can't follow correct grammatical english all the time!). Anyway if you could give a good explanation as to what SLI and Crossfire do, I would be eternally gratefull.
    Thanks,
Jake
Well it gives you about 180% performance boost graphics wise, as it doesnt scale perfectly, more VRAM, and as you said more places to connect monitors. this is just really basic what it can do, it was all I could come up with from the top of my head hope it helps in  anyway.
I'm sorry but no,
1. technically a 180% boost would be over 2x the performance, you mean a 80% boost or
180% performance compared to single card, which it indeed does give. (you had the right idea but math dun' screwed you over.)
2. It doesnt give you more VRAM.
1GB + 1GB in SLI or Crossfire doesn't equal 2GB of framebuffer, because the textures and whatnots in the VRAM need to be mirrored in either card for them to render frames in a game or other fullscreen application.
Also 1GB + 2GB framebuffer equals 1GB of framebuffer and 1GB unused on the card with the bigger VRAM even though software like MSI afterburner might lie about it.
Two cards in Crossfire or SLI technically should have twice the performance output of a single card. But since drivers and games are not usually fully optimized then you'll probably see a 80-90% performance  scaling in games like Iñaki stated. Given that the processor is not bottlenecking your system too hard for there to be neglible effect on the multi-GPU setup.
Card 1 renders a frame, then card 2 renders a frame, back to card 1 and so on is the basic idea behind them.
M.K.
Yeah sorry about that I was thinking that it would give you 180% performance, not boost. Thanks for correcting me. and I thought you got more VRAM but I had the wrong idea on that aswell *sigh* seems I am simply wrong in my knowlegde.
No beings were hurt and the final info should be correct so all is cool.
