SLI and youtube vids
ok so i think ive narrowed down my crashing problem to SLI. is there some way i can keep SLI on, all the time with out having to turn it off to watch a vid.
with SLI on, the drivers will crash after about 4 vids
with SLI off, it will never crash even if i play 4 vids at the same time
any help would be awesome
wut driverS?
when windows reboots, it tells me the problem was caused by the nVidia drivers crashing, i have the newest ones, but it also did it with every set for the past year, when i built the pc
I do know that something is messing up with the fx cards cause the screen will black, lose signal, flash, then go black, mean while everything else is still working, after the last black it'll lose signal(monitor) again and the pc freezes
well with the most recent graphics card drivers maybe you should try updating the browser your using. If that doesn't work then deal with it? :(
Try to use different browsers.
Update ur current video card drivers.
Uninstall and reinstall ur video card drivers.
If those wont work then ur Windows or video card is damaged.
Install drivers the real way. Uninstall drivers, rebooot into safemode, use driver sweeper to clean up shit, then install new drivers in safe mode.
I've done all of that except Greens way, ill try that. if that dont work, looks like im dealing with it lol.
