Skyrin Stuttering issue?
Every time i try to play skyrim, in some dungeons and out in the world my game likes to stutter and screen tear. When i run fraps when it is happeneing my FPS is literally convulsing between 60 and 61. How do i fix this? it is something that really annoys me when i play haha. Im up to date with my NVIDIA drivers, im even using the beta.
My Laptop Specs are
NVIDIA GeForce GT 750m
Intel i7 4700-MQ
8GM Ram
Try going into the nvidia control panel and under manage 3d settings set vertical sync to  adaptive.
I sadly dont have the option in my global settings or program settings to set adaptive v-sync. Only On, Off, or Use 3D Settings.
You sould your gpu supports adaptive v-sync http://www.geforce.com/hardware/notebook-gpus/geforce-gt-750m/features
Did the stuttering start after installing a mod? If so try deleting it (or re-installing it if you really want it)
Try using the newest non-beta drivers. I am using 320.49 drivers with my 660 ti.
Try changing your video settings in skyrim eather higher or lower.
If that does not work I would back up my saves and mods and re-install skyrim.
Other than that I am out of ideas. Sorry I could not be more help. Let me know if you get it fixed.
