Hey everyone
so I installed the same enb as logan is having Poupouri ENB
but I think is to much for my XFX AMD 7950 black edtion i play at like 30 to 40 fps but my temps are at 84 degrees
should I worry or just keep going?
Hey everyone
Yep 84c is preity hot but this is actualy common place for the XFX cards there dam hot and loud its down to them useing to much thermal paste of bad quality on them you can make it run a lot cooler by replacing it with some decent paste.
what can't paste should I use then I have some artic cooling mx5 will that work?
Yep thats a hell of a lot better than the crap XFX used.
Thanks man and wow my last replay I am tried... do you have any guides too tear apart and XFX Card?
http://www.youtube.com/watch?v=mZBpE1t1Y4I
Thanks you so much :-)
