Everytime I enter a new area my skyrim stutters and sometimes fails to load textures so i randomly get stuck in a house, or fort or something when it loads. I have about 150-200 mods on skyrim including numerous texture mods and RealVision ENB. However, when I'm not stuttering my computer runs skyrim at 60 fps. Specs: Mobo: Gigabyte p67-ud7
CPU: i5-2500k (stock speeds, can OC if that's the problem)
GPU: GTX 670 (stock still, can OC if that's the problem)
Also, I have an 120gb SSD but I put skyrim on my 1tb samsung f3 because I have about 25gb's in skyrim files. :p So, can anyone tell me the problem, is it the hard drive? gpu? cpu? Please help
It will just be one of your mods most likely. Its not out of the realm of possibilities that its hardware related but since by the assumption that this is only happening is skyrim,, yeah its a mod issue.
How much ram do you have? What kind of mods do you use? Do you use a lot of HD mods? Nature Mods? etc etc There is a lot of info missing here. My skyrim with 40 mods hits 3-4GB of RAM.
Only 4gb, and I use tons of HD mods, and climate of tamriel is the only nature mod i use, also after it stutters i start seeing missing textures on somethings like doors, walls, and flowers
It could be RAM, check your usage and if it's filling up getting another 4GB's wouldn't hurt, though if you were hitting the 3.1 limit for Skyrim you'd be getting CTD's (as far as I know), so I'm gonna go out on a limb and say you probably have a mod conflict somewhere in there, it's bound to happen at some point with 150-200 mods, also remember that whilst they did make big improvements to the engine it still abhors having too many mods installed. My own skyrim is also pretty heavily modded (HD texture packs, Kountervibe ENB, 100 or so other mods), I have a decent rig and mine still gets pretty bad stuttering when loading new areas even when installed on an SSD.
If you haven't already done so, I would recommend downloading and running BOSS. It will tell you if you have any mod incompatibilities, and it will optimize your load order.
It's probably RAM, I was maxing out my RAM on Skyrim and it was destroying my frame rate and causing stutter. I'd suggest getting another 4GB of RAM. I was hitting about 3.5+GB of RAM and I'm only running 40 mods. I would suggest checking resource manager while running Skyrim and see what your hitting when it stutters.
If your running Skyrim and it's hitting those levels you can pretty much bet that it's your RAM causing your problem. Your OS alone is going to take up more than the 512MB left. I say problem solved lol
