My new 7970 came today. It was on sale for $250. When I overclock my card 1mhz and it freezes whenever it loads a new area. Any ideas for what I should do? I can run 1125 core and 1575 memory for 15 minutes straight no problems in MSI Kombuster.
Bump
I've found Kombuster to be...... not a great indicator of OC stability. It's also not even particularly good at heating up your GPU.
I'm assuming you put this in an already existing system. Did you wipe the old driver? It shouldn't matter, theoretically, if you go from an AMD card to another AMD card, but it rarely "just works" like that in real life.
Are you running any mods on skyrim ?
I'm running a ton of mods on Skyrim. How would you test GPU stability?
Your overclock could be stable, skyrim does run into problems with lots of mods, BOSS helps but there are times when that won't help and it's just plain broken for me and I have to reinstall from scratch. Furmark will insanely stress your gpu, use the lowest settings on furmark and see how hot it gets.
I figured out the problem. XFX actually voltage locks there cards so I can only get 1050, 1500 without encountering problems. I had to boost the power limit by +20. Going through Heaven 4.0 I get to a max of 59 degrees.
Great ! And about mods i was going for the fact that some of the mods can easily stres the gpu more than some of the actual stres tests in my experience
Use some google-fu and if you get lucky you might be able to mod the bios for the voltage unlock! Risky but if you know how you can flash the stock bios right back if it fails.
