So I finally got Skyrim for my PC ( I had already beaten it on my 360) and wanted to know some "must-have" mods! I definitely want to keep the ultimate "feel" of Skyrim and keep it lore-friendly!
I will give my current list so people don't suggest what I have. ^^
iHUD is a must have next to SkyUI in my opinion, it makes the hud much less intrusive. http://skyrim.nexusmods.com/mods/3222//?
Take a look at a follower mod called INIGO, it's a fully voiced Khajit who is surprisingly fun to run around with. http://skyrim.nexusmods.com/mods/40960//?
Give the Frostfall mod a try, it makes surviving out in the cold a little more interesting. http://skyrim.nexusmods.com/mods/11163//?
There is also Immersive weapons by the same mod author of Immersive armors. http://skyrim.nexusmods.com/mods/27644//?
If you want to have a little bit of a change in the combat then take a look at T3ndo's Skyrim Redone, it rebalances the combat and perks, feels very different to normal Skyrim, also removes the cap on skill levels so you can keep leveling without needing to reset your skills. http://skyrim.nexusmods.com/mods/9286//?
Do note that if you're running mods (as you are) you'll want to get the ReProccer and use that so the modded-in weapons/armor integrate properly with Skyrim Redone. http://skyrim.nexusmods.com/mods/28467//?
Uniques uniques gives a few of the named weapons their own look which is nice. http://skyrim.nexusmods.com/mods/33292//?
Ethereal Elven Overhaul gives the elven races a nicer look, though some people don't like it, just give it a look over. http://skyrim.nexusmods.com/mods/24273//?
