Hi,
Does anybody know if the Skyrim HD - 2K Textures mod is compatible with the RealVision ENB.
Hi,
I don't see why not. The ENB isn't modifying any texture files, its just a post processing program.
thanks, I'll give it an install now an see how it goes :)
if you haven't installed an ENB before, make sure you follow instructions carefully, and put the right files in the right places, or it won't work and you will have a hard time.
