Skyrim Issues [Solved}
So i have been playing skyrim on PC for about 4 months, and it was working fine until just this weekend. When i launch the game the game starts fine and shows the "Bethesda" logo but when it changes  after that, it just crashes. I have Nexus Mod Manger with like 12 mods. I have been using the same mods since day one and haven't updated anything at all. Any ideas on how i screwed up?
Something with the mods. Probably one of them automatically updated. I just went crazy with mods and now i cant get past the Bethesda screen either. Just deactivate all of them are re-enable one by one till you find the issue.
Ok ill try that, thank you!
Sometimes if you have some graphic enhanced injector mods there the driver update might be incompatible and crash it for you.
Try this. I got this problem all the time.
