Ok so I have tried setting my FOV in the .ini files and it doesn't work. The only thing that does work is the console command but I have to set it every time I load the game. How do I make it permanent?
"To change your Field of View (FOV) in Skyrim, you must first add both of the variables above to the bottom of the [Display] section of the Skyrim.ini file. Change the values shown to match the FOV degree you wish to use. Next, you must add the variable fDefaultFOV=90 to the bottom of the [General] section of the SkyrimPrefs.ini file, once again adjusting the value to match the FOV degree you want.
Then load your latest save game in Skyrim and use the FOV 90 console command to match the FOV degree set for the variables above, and save your game to make the change permanent."
Get the Customizable Camera mod, if you are into that. http://www.nexusmods.com/skyrim/mods/37347/?
I use it to get 100 fov it is an okay mod and gets the job done
That seems to have worked, thanks :)
No problem, enjoy Skyrim.
