Skyrim/Fallout 3 enb torture
the enbs will not work consistently in either game. i don't know what is happening.
i can't play these games without enbs. tell me what you need to know to fix this.
You should be a little more specific if you want any help. You rig isn't really up for enb torture anyway, you should just mod your game.
th enb is torturing me, well it was then i saw on the net that if you turn off precision x and other similar tools it would fix whatever crashing problems i was having and did remove the problem. i prbably should have been more specific but i was really flustered.
