I am just getting my list of mods completely redone, and I want to include the ENB's in as well. My problem is.... HOW THE FUCK DO I USE THEM?!?!?!?!?! I downloaded the ProjectENB and Realvision ENB so far, but I see no difference. I have them active in the Nexus Mod Manager. Help please?
Put all of the files where it tells you to put them, use the wrapper version, rtfm.
Then use Seasons of Skyrim on top of the default ENB.
I don't understand anything there?
I was going to give you instructions but it's a little pointless when they're on the mod's page: http://www.nexusmods.com/skyrim/mods/30936/?
Scroll down and you'll see steps for installation. You can choose to skip 1 and 2 as they're not essential, but I recommend them, for ENB but they do improve the look of the game. Also make sure you backup the ini files you change before changing them. If you get a CTD when you start up skyrim you might have incompatible programs like MSI Afterburner running which don't work with ENB's.
If you want skyrim to run with these you'll have to delete the d3d9.dll file and use a injector version of the ENB which you place in the root of the skyrim folder and open up before you launch the game.
I tried realvision and projectENB. Then I tried Sharpshooters Classis ENB. WOW! Never going back.
Gopher (on youtube) has a tutorial on how to install this ENB. It's pretty easy, just follow each step.
Second this, the actual ENB for that mod is outdated but it probably looks the best out of the lot. However if you want the game to have more of a vanilla dark look this might not be the best choice because this is quite a colourful ENB.
It is quite bright in terms of colour brightness, but I find the nights to be darker than vanilla which is what I wanted. After a while you get used to it. I find vanilla skyrim is very dull/grey and with way too much ambient light everywhere.
The problem I'm having now, which isn't related to the ENB, is missing (pink/black) textures start to show up and shortly after I get CTD. Still trying to nail down the cause.
But yeah, to the OP: Just follow the installation instructions and it should work.
ENBs have to be manually installed in the main Skyrim directory. Nexus Mod Manager is denied direct access to this particular folder and can only install mods to the Data directory.
Here's the guide on RealVision that MEC-777 referenced. The process is similar with most ENBs out there.
Actually this is the one I'm using (Sharpshooter) and the installation video:
http://www.youtube.com/watch?v=gXdGxYXfMUw
