Why is this happening?
http://imgur.com/q8Pyv46
Is your game modded? Certainly weird
Yes its modded
It looks like there are missing textures. I've never seen that before in Skyrim. I know this is a stupid question but have you tried uninstalling all the texture mods an see how it looks?
I'll give that a go, but it won't be to the weekend.
When I was modding a lot I always got a lot of errors and Skyrim sometimes was just buggy even after removing all the mods. Deleting the Skyrim folder and then reinstalling everything usually fixed that but depending on your internet connection that may take a while.
I've got the same bug and tbh I was too lazy to fix it, I noticed that it got bugged when I installed the dawnguard DLC
To be honest I'll probably be too lazy to fix it as well, but is this a common glitch, if so you'd expect some unofficial patch for it.
Well I don't know if it's common but it isn't that annoying.
Its not annoying, it just breaks immersion a tad bit...
Have you tried disabling your mods before reinstalling Skyrim + DLC and then adding the mods again? I think that might help. I'm running the modded dungeon textures as well but haven't noticed any missing textures in my travels.
If you're still looking for a solution... Are you using Enhanced Lights and FX? It happened to me too. You have to update your Static Mesh Improvement Mod, most likely you have an older version. It's very annoying, I've looked for a solution for days............
Yea, that's a missing texture since it's just drawing the default fuscia. Seems to be for some decal that's put on the wall since an ore vein would be a purple rock and if the walls were corrupted the whole place would be pinkish.
Yes I'm using elfx. I'll update my smim and uninstall texture mods and see what happens.
It was elfx and more specifically the smim meshes from elfx, fine with elfx though
Yep, need the Enhanced Lights and FX SMIM patch. This one made me so mad for a week!
Yea but with the smim patch i get the strange texture...
