So I've come across this odd crash that only occurs when I enter water that is deep enough for me to swim in, now I have poured over different sites and various thread and there is a simple and definite fix to this problem......on ps3! What makes this crash so bad is that while it is a common issues on ps3 that is easily resolved, there seems to be no one in the PC world that is having the same problem, almost like it doesn't exist. Can anyone please help me out?
Other info: Steam Copy of Skyrim: Legendary Edition, have cleared cache and checked game integrity on Steam
The [ONLY] mods installed are a handful from the vast list that Logan has on his second Skyrim Mod Video, along with all Unofficial Patches.
if you downloaded them with nexus mod manager then go down the list of bug fixes first, then look for terrains, textures and models, if that doesnt work backup and re-install and then troubleshoot from there. one of the bug fixes may have brought back that bug.
The following are imgur links with the mods followed by the load orders
http://goo.gl/NGeVIB
http://goo.gl/iM4OEi
http://goo.gl/sFNGBG
http://goo.gl/Ol4ZUo
I've run both BOSS and TES5Edit for errors to my load order and while a number of issues were indeed corrected, the main one (Deep Water Crash) is not one of them
Just an update, I have since deleted everything Skyrim, re-downloaded the game, and re-installed all of the mods and more. I have no idea why, but the crash is gone and has been fixed.
