Skyrim Dawnguard
Is there a way can take the vampires side after saying no to the vampire lord, I can't get back into the castle and if I use commands, the vampire lord has no dialog, is there some kind of command I can use to change back to the vampire side, I changed my mind :/
help?
No once you pick a side you work for that side you can allways load a older save and pick a differnt side.
