Skyrim at 2560x1080?
I'm trying to get Skyrim to run at 2560x1080 without having the terrible stretching issues. I've already tried forcing the resolution and I've tries a few widescreen fixers.
Has anyone had any success with 21:9 aspect ratio with TESV? If you have how did you do it?
i dont have a 21:9 aspect ratio for my monitor. but i suggest changing the FOV of skyrim. This might not work but give it a try
in the options part of the launcher are you able to set the aspect ratio to 21:9 and the resolution to 2560x1080? that should all you have to do.
