Hey everyone,
I decided to join team blue recently and I upgraded from a fx6300 to the i5 6600k, but when doing the build I had some issues. The first gigabyte board that I bought was DOA and only one of the RAM slots worked. I then went with the MSI z170a gaming m7 which is really great, and I highly recommend it. Though I do want to share a problem that I ran into. I got Windows 10 to install and it was running, but every hour or so I would get a BSOD. After running Memtest86 it came back with errors during test 9. Initially I thought I got some bad ram, but when I took it back and got a new kit I still got the errors in Memtest86. Long story short I figured out that the default voltage was too low and that was what was causing the instability. I turned on the xmp profile and turned the voltage up to 1.35v and that fixed everything. I don't know if anyone else had this problem because I couldn't find anything while searching the web for it, so I just wanted this info out there!
FYI and specs:
i5 6600k
MSI z170a gaming m7
Evga superSC 4x4gb ddr4 2800 (it's basically rebranded g skills ripjaws)
-the first memory I tried was the corsair 2x8gb 2666
Asus R9 290 direct cu ii
Cx750m
Cooler master nepton 240m
