Skylake's IMC officially supports only DDR3L with a voltage of 1.35, and it officially supports DDR4 at 1.2 V ... but these voltages are likely used to avoid damaging the IMC.
Thoughts? I guess it refers to boards like the Asus Z170P D3, which even support DDR3 up to 3100mhz. That's often above 1.5v - usually 1.65v.
Yeah I have seen some motherboards that were ddr2 to ddr3 hybrid motherboards don't know much about them but all i knew is that for ddr3 your ram has to be at 1333mhz and lower something since the cpu were not made to handle the higher speed ram cause of ddr2 limitations.
I really wouldn't mind seeing a review of this board, with a good Skylake CPU installed, with both an equal size and performance comparison against DDR3 and DDR4 installed. I bet the result would favor DDR3 if price was involved, but its possible DDR4 could destroy DDR3 if everything was left equal. Just depends on how well Skylake responds to the DIMMs installed...
I'd be surprised if these wasn't a 'crossover' mobo out there somewhere that had ddr3 and ddr4 slots on it like the old AMD mobos for amd phenom 2's that had ddr2 and ddr3 slots on it lol
