Size for USB FreeNAS?
Hey guys!
Quick question, what size USB should I use to install FreeNAS on to? I plan of installing it on a USB for use in the server, so its not on a HDD. I have an 8GB, would that work?
Thanks!
Last time I set up FreeNas I installed it onto an 8GB stick so you should be fine with that.
cool thanks mate
you can get away with 4GB. 8GB would be recommended. 16GB should be perfect.
yeah that's what I thought thanks
your welcome
