Sites and stores with a good database and filter function for hardware
see topic. As an example, PriceSpy is great if you’re looking for a mini-itx motherboard that can take at least 32GB ecc ram, Newegg can do something similar, but not as well (imo). MicroCenter actually works better then, but not as good as PriceSpy. The weak point in all these are that they only show the hardware that are for sale in any of the stores they cover. PriceSpy keeps the data in their database, but you can only access it via a search engine. The best would be a huge database of computer hardware from the birth of time, but I don’t think there is one like that. And no, it’s not very good to google it either.
So, do you know of a good site with filter function for pc hardware?
Edit: Mini-itx.com is pretty good too.
https://geizhals.eu/ is for EU but they do have an insane filter system.
idealo.de works pretty well too (and also show a few other EU countries too in desktop mode)
Nice! (Mini towers 35-40cm that can fit an ATX motherboard.) German isn’t that hard :slight_smile:
120mm fans that are 30mm thick. There we might have the answer to why Arctic BioniX P120 ARGB is better than the normal P120.
