Single Slot NVIDIA GeForce 750?
Hello!
After recently receiving a used computer, pre-installed with a NVIDIA 8400GS, I am in search for a new GPU. I have done some searching, and the 750/750Ti GPUs seem to be the best "bang for the buck". Due to lack of space, the system can only manage to fit a single slot GPU. I haven't been able to find any variation of this card capable of fitting in a single slot, so I have come to you guys for help.
Preferred to have an EVGA card, though it is not necessary.
If a 750 is not available (or if its out of my budget), Then I will just purchase a 740 SC, as they are available in a single slot variation, and are much cheaper (And less powerful, sadly).
Thanks!
--xVxM4tthewxVx
as single slot as ur gonna get http://www.newegg.com/Product/Product.aspx?Item=N82E16814127836 (750ti not 750)
750 http://www.newegg.com/Product/Product.aspx?Item=N82E16814121854
Well, sadly the Asus model won't fit in my PC. :( The MSI is also somewhat pricey for the 750 Ti. So I think I might get a 740 Single slot. It seems like a better value. I don't plan on doing any heavy gaming, (Just games like World of Tank and War Thunder) so I think the 740 will get the job done.
Thanks for helping me find these cards though!!!
