First time build: Planning for an eventual four GPUs I’ve over-engineered a bit with the PSU: a Supernova P2 1600. (Well might not be that overboard at the end of the day if I really get four x080 Ti’s in there
Based on the many forum threads, I plan to power my 2080 Ti(s) with separate cables.
Question: The Supernova is a single rail PSU. Is there any difference between the “VGA” (PCIe) connectors 1-4 and 5-9 which are designated differently in the manual? (See below). My naive approach is just to treat them all as 8-pin power sources… but is there any magic in those 5-9 connectors that specifically say they are for “6pin plus 8(6+2)”. Seems like they are just begging me to plug one of those dual cables in which are included in the box.
Thanks. Yup, I gathered I could just leave the extra pins hanging. (Or I could just buy extra 6+2 -> 6+2 single cables to get rid of the extra 6 pins all together.)
I am just curious why EVGA would go through the trouble of actually designating 5-9 separately when the actual power is the same for all nine.
Anyway, thanks. I just wanted to make sure. Appreciate the quick feedback.
I loathe piggybacked cables, but I understand some people prefer to use a single 6+2+6 cable for cards that use 6+6 or 8+6 connectors. I certainly wouldn’t use them for beefcake cards like a 2080 Ti, but for a 2060 they’d most likely be fine.
EVGA probably just did it to be accurate since the cable layout is different.
