Hi,
Hoping to glean some knowledge from the community and create a resource for others that are facing a similar dilemma.
Scope:
Looking for product/solution/hack to create multiple virtual monitors on a single 4096x2160 display within Windows 10. The virtual monitors would be detected as separate entities and be able to assign dedicated full-screen application control. Example screen split would be 2x 4096x1080.
Background:
I’ve recently purchased an LG 50" 4K TV (model 50UK6540PTD) that is really nice for PC gaming and productivity. Unfortunately does not have the LG monitor screen-split software as part of it’s package. Has changed my mind about using multiple physical displays to a single big display.
Initial Research & Testing:
Display Fusion Pro - Can set screen regions to snap, but not detected as separate monitors.
Borderless Gaming - Can set per application resolution and force borderless window. (Current solution).
nView - Unable to run without a Quadro, only have single graphics GTX 1080 in system. (Possible can run both in system, requires obtaining a Quadro card).
UltraView Desktop Manager - Looks similar to Display Fusion but no trial version to test. ($99USD is a bit much to gamble).
That’s everything so far but light bulb idea just now, maybe powershell can help in creating virtual monitors? Thoughts?
Cheers from the land down under.
