TL;DR: Recommendations for a simple window manager?
Requirements:
- high configurability through dotfiles for keeping in git
- very keyboard centric
- static workspaces, capable of multiple monitors per workspace
- configurable for window stacks first, tiling optional or none
- basic amenities (status bar with system tray, window list and workspace indicator)
Longer version:
Cinnamon broke after an update so I revisited hyprland and once more found the workspace logic bordering on insanity. I’ve also came to the conclusion that tiling doesn’t make sense, I only ever tile terminals and I do it in tmux anyway. You can configure hyprland but it seems counterproductive trying to mold it to something that it is not.
Can you recommend an alternative? It’s hard to assess alternatives in advance without going in head first, one by one. I did use AwesomeWM in a distant past, but I’m honestly clueless if I’ll be able to use it in the future should Wayland become the default on major distributions.
