Simple Surround Sound
Using two USB DACs each driving a 2-channel amplifier with a pair of speakers, you can get four full channels of uncompressed surround sound.  No encoding standards such as Dolby TrueHD are necessary.
If someone wants to make a crossover and use a subwoofer that's fine, the information is there in the 4 full channels.
This removes the need to buy a new AVR every few years, and removes the need to use proprietary compression standards except when decompressing the source such as a Blu Ray disc.
Games can construct the four channels however they are best able to (presumably in software with GPU assist), and streaming video/audio can use a flexible compression format that can be changed at will, since no user hardware sees the encoded material.  It's all decoded before it goes out USB.
Upgrades to more channels or faster connections (Thunderbolt) are obvious and inexpensive.
This setup creates a channel between artist and listener that is accurate ("transparent") and cheap.
Someone must have tried getting traction with this already…?
