Ok guys and gals, today I was approached by a friend who asked if I could build a PC for his dad's office. Of course I said I could and would, not realizing that the few PC's I have built for myself and friends are quite different from the needs of this build. Normaly the PC's Im putting together are the high end gaming performers with multi gpu's and overclocking headroom,
This time arround I need something sub $500(no graphics or sound cards ovb.) that will be built to stay running for a week or so w/o restarts, has decent networking capabilities, and has usb3 and sata6gb/s. Also looking to include a ssd bootdrive w/ a 500Gb hdd storage minimum. Another thing...case and monitor must be included in budget.
Any help is appreciated, as stated I'm not really well versed in components other than the higher end stuff. Also not too familiar w/ AMD's tech and I know that they tend to be more budget friendly.
Some of their low end OptiPlex are $440 that includes an operating system. Then you're tasked with finding cheap monitors to fit the $500 budget.
It's pretty hard to include something that looks office appropriate, includes the operating system and costs basically nothing.
I'm going to assume pirating windows is a bit out of the question since it's for an office setting but I'm sure someone here will insist that route because they believe Microsoft doesn't deserve any money and bla bla bla
CASE: 40$ http://www.newegg.com/Product/Product.aspx?Item=N82E16811129186 --Antec VSK -3000 or http://www.newegg.com/Product/Product.aspx?Item=N82E16811163223 --Silverstone PS08B (if you want USB 3.0 front header)
Well here's the best I could do with that budget: http://pcpartpicker.com/p/x6F7
The CPU is last gen but it's still a quad core which should be future proof for a few years. The Llano APUs are the cheapest quad cores around at the moment and you'll find good sales on them and their motherboards now and then.
Here's a dual core Intel alternative: http://pcpartpicker.com/p/x6RU
Your FM1 buid is bugged and doesn't display the price of the ram properly so it's a bit over. Although if you remove the optical drive it may just fall just within budget. Pretty nice.
