Hello all. I’ve read a few post on DIY NAS but none seem to fit my unique requirement. One common theme is build a system based on individual requirements but none seem to address my needs so I’m hoping by posting here, someone can help me. I currently have a Synology DS2413+ running out of storage and the unit is beginning to whistle and am afraid it’s at its EOL. I mainly use my Synology as a network drive to my computer. I VPN when I’m out of my home office but occasionally use Synology cloud “drive”. I have issues with the cloud drive when using 3rd party equipment so VPN is always my best option. I started converting my CD/DVD so I can start using Plex (maybe switch to jellyfin) but that’s when I started maxing out my current machine and decided on building my own.
So I bought 2 server cases (12- bay & 20-bay). The 12-bay will be used to replace my current machine where it will be used for storing work documents and accessing them the same way. The 20-bay will be used to run and store a media server and all its content. I’ve decided on an Ultra 5 CPU for the 12 bay and then maybe the same for the 20-bay but may consider the Ultra 7 or 9. Will use the new W880 MB and ECC RAM.
My issue is which OS (unRaid, TrueNAS) to use and what programs to use for my file management (next cloud, owncloud, etc). Originally I was going with unRaid because I like the flexibility of increasing my HD space without worrying about size. I did not like how Synology addresses adding HD and why unRaid was an appeal. But I’ve been reading that unRaid is slower and TrueNAS would be the faster OS. I’m now considering unRaid for the 20-bay for its flexibility and TrueNAS for the 12-bay so I can have faster file access of my work docs because of ZFS. I know unRaid does do ZFS but not sure if it’s the same or different than TrueNAS?
Finally, the file management portion. Synology just works but it’s at a premium with limitations. I’m semi tech savvy but I can’t have my system crashing or failing, especially when I’m traveling and will not be able to access the equipment to troubleshoot. Let alone come home or even spend days fixing any issues and loose valuable work time. Forums say next cloud is great but other report it constant needs watching and updating. Have not looked into owncloud but I’m guessing it is probably the same hand on.
I would be happy to pay Synology for access to there OS but they do not offer that.
Does anyone have any suggestions. Thank you in advance.
