SilverStone TJ11 - any thoughts?
OK, just look at the pics, and forget all about the price.
In short, this is what you get if you mix the succesful design of TJ07 with the cooling of TJ10, and revolutionary FT02/Raven keyfeatures in SilverStones lab; one huge piece og solid 2mm thick aluminum monster that eats all your hardware... alive or dead, I don't think it matters.
Here's the TJ11 housing an Asus Rampage III Extreme along with 4x HD5870's in CrossFire, and a ThermalRight HR 02 CPU heatsink with NO fans. Note 90* rotated motherboard tray.
[img]http://www.expreview.com/img/news/2010/11/01/silverstone_tj11_09.jpg[/img]
TJ11 with GTX 580 3-way SLI, and a 560 radiator (4x 140mm) side-by-side. Note the two 180mm Air Penetrator fans blowing cool air up in the case.
[img]http://img155.imageshack.us/img155/4892/ct10silverstonetj111.jpg[/img]
"Will it fit?" - you bet it will! 560 radiator in TJ11. No more need of external radiators!
[img]http://www.itrends.dk/wp-content/uploads/2010/11/tj11-19-650x406.jpg[/img]
SSD support? No worries. Up to three 2½ SSDs can be installed on the left side of the 5 1/4 drive-bay slots. Cable management looks neat. Note, the two fans at the HDD cages will be changed with AP fans when the final product is out.
[img]http://img52.imageshack.us/img52/1856/ct10silverstonetj116.jpg[/img]
Naked shot of the beauty. This case (like TJ07) supports XL-ATX motherboards.
[img]http://www.techyglobe.com/wp-content/uploads/2011/01/SilverStone-TJ11B.jpg[/img]
Front-view of the case. NINE(!!!) 5 1/4" DRIVEBAYS! Enough room for Blu-ray, DVD-burner, fan controllers and w/c resevoirs? Keep in mind, that you can move the HDD cages up in the 5 1/4 bays if you want a radiator in the lower level ;)
[img]http://extreme.pcgameshardware.de/attachments/299900d1294180527-silverstone-stellt-temjin-tj11-und-fortress-ft03-vor-tj11-bild3.jpg[/img]
One last shot of the case. Note the two vents between the two levels. These are for the 180mm AP fans to intake cool air. There are dustfilters that are easy to take out for cleaning, without having to remove the sidepanel.
[img]http://www.dvhardware.net/news/2010/silverstone_tj11.jpg[/img]
What else is there to mention... this case is so huge that it has TWO power buttons (lower front panel and top panel, in case a midget got hands on this). USB 3.0 and 2.0 support. Did I mention how big it is? LOL!
Please, leave a thought/comment. :)
OH SNAP! Before I forget! The price is expected @ $699. Good luck digging your wallets (same $#!t for me).
- Ruffe
