Three big questions
does anyone know for the for the
SilverStone Storage Server Chassis SST-RM23-502
how much space is between the back of the 5.25 bays an the divider wall without fans mounted on that side ?
can the divider wall be removed ?
can the 3.5in drive bays be removed ?
my reasons for asking an wanting to are
i like the case a lot an im going to buy it an mod it if i can like this
im going to use a FSP Group Dagger Pro 650 SFX Power Supply
to allow more room behind it
to mod the bottom of the case with a 3x 120mm fan cutout template guide for bottom intake
an if the divider wall can be remove id use my drill press an hole guide to turn the whole in to a mass vent an reinstall with mild filter mesh both on it an the bottom intakes to control dust an not choke air flow
an then on mobo side add fan cutouts for a 240mm rad above the mobo in the cable manage area config-ed as intake an both side wall make 4 x 80mm fan vent cutouts as exhaust
