So heres the start of this. I had built the loop and was very happy with the cooling. I can Include a full parts list later. I still need to drain and refill.
I have to give a huge shout out to Alphacool!!! I had cleaned my U1 CPU block and in doing so I crashed about 6mm of the fins when the jet plate got out of place and I clamped it down. My bad. They sent me a new cold plate free of charge! I can not believe it. Took them about 24 hours to respond. The shipping of course took some time due to overseas travel, but wow. What a company customer service. I only asked if I could special order one because I damaged it. I did not expect a free replacement!
I know its rough now, but I plan to add a thin plexi plate and some rivets then clean it up and install the RGB strip on the Phanteks Glacier reservoir. I probably need to paint the Noctua fan in the rear and hide the gpu power cable. I may drill some holes in the plexi in a pattern to help with ventilation?
I dunno, see how it goes. I already managed to fit a 240mm and a 120mm radiator, a full res, and a DDC pump. I have a CPU block and a full GPU block.
