I changed the CPU cooler on one I'd my build yesterday but when I plugged it afterwards the first light from the bottom is red fading to blue on top. Before the top two were always blue so I do not know what the red means.
Google disagrees with the existence of such a case...
However, can you trace what those lights are connected to?
It is part of Silverstones Kublai series I guess. Yeah google wasn't much help so I asked a couple of forums. You are the only reply I got. I'll see what I can do in a couple of hours about tracing the lights.
What do you mean where I connected the LED? The power wires that go into the mobo? The wires for those are routed in the front panel with screws everywhere. I did not think I would have to go through dismantling hard drive cages and front panel, etc to check what LED colours mean. Dammit Silverstone.
You don't really need to...
You have your front panel connection cables, you disconect them one by one. The connector should have HDD or Power or whatever. So you connect only that from all LED cables, and only one LED will light up. Then you connect the second one, etc.
I guess you follow my trainwreck of a thought...
Now I follow. Cool will try it out later, see if it works.
It is the HDD light. But using HDTune I checked the drives and they seem fine. The only explanation I can get is that that is the default colour for the drives and when I did it before I probably did it wrong.
You probably did not connect the red one properly. And the blue light just glowed throughout...
