Silent PC without watercooling
What's the best way to get almost silent system on budget. I am running i5 3570 non k+Gigabyte gtx 660 oc. That's my workstation/gaming rig. Thank you guys for help.
replace your fans with quiet ones or reduce the rpm of them with the motherboard/software or fan controller
do i need to get a heatsink
http://www.amazon.co.uk/Cooler-Master-Hyper-212-120mm/dp/B0068OI7T8/ref=sr_1_1?s=computers&ie=UTF8&qid=1388169629&sr=1-1&keywords=heatsink
Since it's a stock CPU, I'd just throw a huge cooler in there, like a Phanteks PH-TC14PE, Dark Rock Pro 2, NH-D14, or SBE, and either remove the fans, or drop them to 800 rpm(ish) (or just put them on 7V, which should be quite enough).
Loudest fans in a system are usually the GPU fans. I'm faced with the same issue and I'm looking into the kracken g10 to replace my evga acx heatsink.
