Silent GPU for workstation? (5k, 60hz, nothing crazy)
Hello all,
I have a linux workstation on my desk and the current GPU inside of it hisses like a snake/cat when the fans power up at all. It is a Powercolor 6600. I do not need beefy GPU features for this machine, just something to run a 5K display at 60hz without any stutter or hiccups.
The majority of the time it is completely silent and the fans are off. Once it gets mildly stressed (certain web pages, etc), again even if fans are at a low speed, it hisses very loud. Then the fans will ramp up for a second, cool it, and it goes back to being silent. This happens all day long and it drives me nuts. I’ve played around with fan curves and nothing really seems to help, as the mere activation of the fan circuitry seems to be what causes the hissing. The hiss is louder than the fans up until about 30% fan speed.
Previously in here I had a 6750XT OC triple fan red devil, but that made more noise at idle than this card. Hence why I downgraded (for pure silence!)
Power:
  • PSU is a Corsair 1000W
  • Connected to a surge protector on my standing desk
  • Connected to a Cyberpower 1500VA UPS
  • In a rental unit so I cannot speak to the quality of the power at the wall
Can anyone offer any tips or suggestions? I want something that is silent under any load but gaming and works on Linux so I am going to stick with AMD.
Is it this kind of sound? https://www.youtube.com/watch?v=HP73edpQwgc (Ignoring the whine of Linus’ voice …).
If so it sounds like coil whine, unfortunately not a lot you can do about that. Personally I’ve found under clocking / over clocking / changing power target can help reduce coil whine. AFAIK it’s basically luck of the draw, and coil whine can be per unit, per model, or situational due to your components.
