So far my favorite case that keeps everything quiet is the Fractal design R4 but i know theres more out there,so are there any more that are better in anyones opinion?what about cheaper cases that keep things quiet?
well there is the Fractal Define XL R2, which is just a big R4
Well, if you are looking for quiet computing, Fractal Design is ALWAYS the way to go. They have a variety of cases that have amzing sound dampening foam on the inside of the case to isolate the sound. I have the Fractal Design Define R4 as my case and I am in love. I would never switch back to my CoolerMaster Stacker again.
The antec P280 looks nice.
I just bought a Corsair 550D, and it is an incredible case. I highly recommend it if you are looking for a great silent case.
I have the Corsair Carbide 500R, and Corsair makes pretty silent cases... My case has quite alot of fan spots and has rubber stubs so the fans dont shake and also has sound densening foam too so it makes it pretty quiet.
The Coolermast Silencio 550 is quite decent i hear. They are only $80 at my local store
I've heard good things about the Nanoxia Deep Silence, mostly version 1 but the 2nd has got decent ones too. Personally I am using the R4 though.
I agree I just bought one of these and the build quality compared to its competitors is unmatched.
I've heard good things about the NZXT Phantom. I've heard it's a very quiet case (Logan mentioned in a couple of his videos) as well as having some of the best airflow of any case on the market (again, mentioned by Logan). It is a bit pricier than the Define R4 however.
