Hello Tek Syndicate.
So I've been using my Fractal Arc Midi R2 for about 5 - 6 months now, and I love the case, but the noise from some of the fans, mainly the CPU fans, has been annoying me a bit. They aren't super loud, but they make a loud enough hum to annoy me.
With that in mind, I was thinking about selling my case to a friend who needs an upgrade, and buying the Define R4, due to its noise dampening qualities. My fan set up will the same as it is now: 1 fan in the front blowing air to my hard drive and SSD, 1 on the bottom blowing air to the GPU, and one fan on the back exhausting air. With that set up, I could leave all 3 moduvents (the one on the side panel and the two on the top) in place to further reduce noise.
My question is, does the noise dampening actually work? I know that no amount of noise dampening can shut up a GPU with it fans running at full blast or anything like that, but I was wondering how well it is able to eliminate humming and rattling noises, the noises that really annoy me. I've heard some people say that it does do a good job of reducing noise, but I've heard others, particularly Lauren from TastyPC, say that it really only deepens it.
So what do you guys know? I'd like to hear from people who have either used this case personally or know enough about it to give a good answer so I can decide whether or not to buy.
Thanks guys!
*side note: I do plan on buying 2 Noctua NF-A14 FLX fans and putting them on the bottom and rear of the case, to replace the weak Fractal fans*
